Lu47Dan
Post
by Lu47Dan » Fri Mar 30, 2012 8:10 pm
I started making a fixture for mounting a dial indicator to the trapezoidal my lathe.
Cutting the stock for the clamp
Stock squared up, ground and slot laid out.
Relief slot milled into the clamp, the relief slot is to allow for clearance on the top of the way.
Dan.
1956 420C with GSC blade
Lu47Dan
Post
by Lu47Dan » Fri Mar 30, 2012 8:38 pm
The next step was to cut the angles to match the way. This involved setting the block up in the mill at 35°, and then taking cuts off one of the corners. Since the two angles add up to 70°, you also have to trim the opposite corner of the groove to provide clearance to cut the groove to the proper depth. Once I had both angles cut I test fit it to the v-way.
Fits pretty good.
Close up.
Lu47Dan
Post
by Lu47Dan » Fri Mar 30, 2012 8:44 pm
Close up pictures of the groove.
I will have to grind the faces of the angles to remove the tool marks on them.
Dan
Lu47Dan
Post
by Lu47Dan » Tue Apr 24, 2012 1:12 pm
I did finish up this project last week, and had to jump to another project
So here are the photos of the rest of this one.
Clamp finished.
Ready to locate and drill a 25/64" hole to tap at 7/16" - 20
The clamp and base assembled.
Ready to cut off the excess steel.
I used the drop piece to make the block that the Indicator mounts to.
Dan.
Lu47Dan
Post
by Lu47Dan » Tue Apr 24, 2012 2:50 pm
I had to mill the block down to 3/4" X 3/4", I then drilled two holes to bolt it to the base.
Test fitting the block.
Block bolted down, indicator mounted and ready to be assembled.
I milled a step into the end of the mount to help with alignment.
Finished mount.
Another view.
I have to drill and tap for a stop bolt before I paint the assembly.
Dan.
Lu47Dan
Post
by Lu47Dan » Mon May 07, 2012 6:09 am
Steady Rest
The start of the steady rest, this flange is a 6" 150# RF Slip-on flange, it was just tacked to the pipe.
The backside of the flange.
The shoulder removed and the flange cleaned up.
Cleaning up the face, the RF above in the description of the flange stands for raised face. that means the sealing face is about 1/16" higher then the rest of the face.
Now the flange is a ring, 7/8" thick. 11" in diameter with an ID of 6-3/4"
Dan.
Lu47Dan
Post
by Lu47Dan » Mon May 07, 2012 6:15 am
The base machined and test fit.
The base aligned as it will be in the final product.
The clamp block. I milled steps into the end of the clamping block to help align it to the bed ways.
The base with the bolt slot milled into it.
andregrondin
Post
by andregrondin » Mon May 07, 2012 6:25 am
HI !
That is great machinist work !!
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
Lu47Dan
Post
by Lu47Dan » Mon May 07, 2012 6:25 am
One of the two stands with the edges beveled.
Ring with the position of the stands laid out.
The stands ready to clamp to the ring and the base plate.
Clamped up ready to weld.
Welded up.
I will be working on the arms or fingers today.
Once this is finished I will give it a good sandblasting to remove the the welding smoke stains and give it an even finish before I paint it.
Dan.
Lu47Dan
Post
by Lu47Dan » Mon May 07, 2012 6:34 am
andregrondin wrote:HI !
Andre, thanks. I trained as a Tool & Die Maker but never pursued it as a career. I could not stand at a machine all day now for sure. I have to break up the machining jobs into sections, so I do not get too bored watching the lathe run. The mill and surface grinder are easier to spend time on as they require operator input to function correctly.
Dan.
Lu47Dan
Post
by Lu47Dan » Mon May 07, 2012 8:21 pm
Here are pictures of today's progress.
Tubes cut to 4-1/16" for test fitting of them to check clearances.
The tubes clear the carriage my a large amount, so I can make my hand wheel in the 2" range.
Set up to mill a 30° angle on the top of the stands.
Milling in progress.
Dan.
Lu47Dan
Post
by Lu47Dan » Mon May 07, 2012 8:26 pm
More photos.
Milling complete.
The set up.
Milling the angle on the two stands was done so I could get the steady rest as close to the chuck as safely possible.
Ready to start machining the pieces for the telescopic arms.
Dan.
andregrondin
Post
by andregrondin » Tue May 08, 2012 5:44 am
Hi !
great work I love when people are making there own tools .
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Lu47Dan
Post
by Lu47Dan » Tue May 08, 2012 9:52 pm
Andre, making my own tools is a lot easier than it use to be!
The rain that had been holding up a couple of other projects, let up around noon today. So I finished cutting up an old truck that pieces of it will live on in another project of mine. I had the rest of that truck two old trailer and a front suspension from another truck to cut up and send to the scrapyard today.
I saved the pieces I needed and the rest of them will go to the scrapyard in the morning. I still have the front suspension from the first truck to cut up in the morning as I had to pull the engine out of it before I could cut it up. I just plumb ran out of light to cut by tonight.
I saved the rear axle out of the truck to get the spindles and axle tubes out of it for the project in this link.
http://www.shopfloortalk.com/forums/sho ... php?t=6677
I have been gathering parts and pieces and the machine tools to build it for about six years.
The steady rest will be an integral part of the machining of the axles for that project.
Dan.
Lu47Dan
Post
by Lu47Dan » Thu May 10, 2012 8:43 pm
I got the final materials for this project today, a 3' piece of 3/8" threaded rod and a 4' piece of 1 X 1 tube to make the telescoping arms.
I might get a 7/16" - 14 tap and go bigger with the threaded rod, instead of the 3/8" rod.
Dan.
Users browsing this forum: No registered users and 156 guests
