steering clutch housing
What is the "cap" that goes on top of the steering clutch housing under the seat of a 350C? In the john deere parts diagram they call it a "pipe plug". If I go to a hardware store and get a "pipe plug" (I'm guessing 1 1/2") would that be correct? I also see that in the parts diagram there is a "gasket" with no part number or anything. Would that just be an O-ring?
The plug you are referring to is the steering clutch housing access plug. You can adjust the brakes through this access.
I've never heard of anyone using a regular pipe plug for this application. It may very well work but I would suggest you go ahead and get the one from Deere. It will come with an O-ring already installed on the plug. When you install it, do not over tighten it as it is a "Bear" if you pull a thread. Tighten it just snug so it doesn't leak and wont back out on its own.
Users browsing this forum: No registered users and 444 guests
