Little something i do for fun.......lost foam casting
sbjuke
Post by sbjuke » Tue Feb 28, 2012 10:10 pm
JUKE
sbjuke
Foam placed in sand and aluminum poured
Post by sbjuke » Tue Feb 28, 2012 10:12 pm
JUKE
sbjuke
after very little cleaning in lathe
Post by sbjuke » Tue Feb 28, 2012 10:13 pm
JUKE
sbjuke
my old but great lathe
Post by sbjuke » Tue Feb 28, 2012 10:14 pm
JUKE
sbjuke
my homemade forge....melts bronze like butter
Post by sbjuke » Tue Feb 28, 2012 10:17 pm
Image :twisted:
JUKE
sbjuke
Post by sbjuke » Tue Feb 28, 2012 10:31 pm
Image...........many things you can make using this method .THANKS FOR LOOKING>>>>JUKE[color=red][/color]
JUKE
andregrondin
Post by andregrondin » Wed Feb 29, 2012 8:47 am
HI !
Nice work ! this is Alu casting ??
the pink model was made with higbn density foam cutted with a heated wire ?
very good work you did there !! I'm impressed.
regards
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
Post by Lavoy » Wed Feb 29, 2012 9:04 am
That is way cool.
sbjuke
Post by sbjuke » Wed Feb 29, 2012 9:06 am
yes this is aluminum.....hotwire is the way to do this....nichrome wire then i just hook my welder to it and turn the amperage way down so it 's just glowing..........works great.............can also use brass bronze or copper this way..........thanks for looking......JUKE
JUKE
sbjuke
Another example of what you can do with this!
Post by sbjuke » Wed Feb 29, 2012 10:00 am
broken fin on boat prop.....shape new one with foam piece
JUKE
sbjuke
pour aluminum in mold and it takes the shape of the foam
Post by sbjuke » Wed Feb 29, 2012 10:03 am
rough cast aluminum fin with sprue attached later to be cut off
JUKE
sbjuke
sprue cut off ...
Post by sbjuke » Wed Feb 29, 2012 10:05 am
sprue cut off ...fitted .....welded......ground,balanced and as you can see in the next picture..........like new again!
JUKE
sbjuke
ready to go fishing once again!!
Post by sbjuke » Wed Feb 29, 2012 10:12 am
I have been repairing boat props for 15 years.......and welding aluminum projects for 25 years .......to many pics to list here and weigh down lavoys great site.............just thought guys like all of you can appreciate things like this...looking forward to a great time here on this site.................thanks juke
JUKE
roadbuilder
Post by roadbuilder » Fri Mar 02, 2012 12:25 pm
Very interesting! Thanks for sharing this with us.
kedorland
Post by kedorland » Wed Mar 07, 2012 5:54 pm
I've been working metal and doing shirtsleeve repairs for 30 years but anything I've done, or built, pales in comparision to what you've shown here. I must say I proudly tip my hat to the master.
Kevin from Iowa.
1975 450C. 1977 450CA loader, with winch and log arch. Is true..tracked equipment is addicting.
