help needed to remove 350 straigh clutch fork
andregrondin
Post by andregrondin » Mon Feb 13, 2012 10:47 am
Hi !
I need some advise and trics on how to remove the clutch fork on my
350 straight ,
1- did put some penetrating fluid ( 3 times )
2- hit gently with a brass rod and a hammer
3- hit harder with a brass rod and a hammer
4- heat up the fork ( to a red status) with a torch and then bury it
with snow for a fast cool down
5- repeat step 4 three times )
6- repeat step 3 three times
7- here on the forum to get others idea and advise .
thank you in advance for any help .
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
Post by Lavoy » Mon Feb 13, 2012 2:52 pm
Heat it up again, but when it is glowing, try and push the shaft out, air hammer works the best. Heat and quench can lead to cracking or hardening, I would not advise it.
andregrondin
Post by andregrondin » Tue Feb 14, 2012 11:19 am
Hi !
I will try that this evening !!!! thank you !
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
andregrondin
Post by andregrondin » Wed Feb 15, 2012 6:34 am
Hello !
EUREKA !!! the shaft & fork had been removed and still in good condition !
I was able to remove the sleeve and then the little cover from under the shaft and the use a long brass rod and use my zipgun and then drive the shaft down slowly and then voila !!!
The spring is shut dead due to heat but all the rest is intact !! oh boy was I happy !!! no I have to clean all the wholes and components then make sure the shaft hasd a smooth surface and then remount the whole thing .
thank you to all for help and trics !!!
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Users browsing this forum: No registered users and 444 guests
