working in the snow
working in the snow
I am new to this bulldozer thing I have purchased a 1981 450c and have used it in the fall before the snow came. My question is when I used it the first time in the snow I was getting some spring compressing and a bang, is this caused by the snow packing up on the sprockets......should I loosen the track tension?
- Al Swearengen
Re: working in the snow
Don't you just love that sound??? BANG! I made some 'snow skirts' for my 450...haven't had a chance to try them though...very dry year!bigkahuna705 wrote:I am new to this bulldozer thing I have purchased a 1981 450c and have used it in the fall before the snow came. My question is when I used it the first time in the snow I was getting some spring compressing and a bang, is this caused by the snow packing up on the sprockets......should I loosen the track tension?
I have no idea if it will help, but when I tried to noodle it out, I suspected the bulk of the snow falling into the bottom of the tracks was from it falling in when turning...the skirts may help prevent this somewhat.
Aloah Big Kahuna : Ist off you should be pushing sand in Hawaii rather than snow in Canada, Holes in the center of the pads are the answer to your problem. In the early 80's when the 850 Case 6ways came out they had no holes in the pads ( where the sprockets meet) , and we were constantly breaking the bolts holding the pads on. Then case went to a (want to say) 5/8" dia hole which wasn't much better. When they went to the big opening that solved the problem. You will find out you will have the same problem in certain clays. Dave
