transmission temperature sender
dudedigger
Post by dudedigger » Wed Dec 28, 2011 6:14 pm
Hi, I have a 450 john deere crawler, my trans temp gauge is inop . I have the factory shop manual and operators manual and none of them show were the trans temp sending unit is located can anyone help on the location of the trans temp sending unit. Thanks
450 john deere crawler loader
LeonardL
Post by LeonardL » Wed Dec 28, 2011 7:01 pm
On a 450E and on 400Gs it is mounted in the filter cap on the lower right hand side of the transmission and HLR case. Right hand as if sitting in the seat. Not sure on older models. Maybe some of these other guys can be a better help.
77 Ford
Post by 77 Ford » Thu Dec 29, 2011 7:53 am
On my 450c it is on the right side of the transmission in the top of the cap that you remove to clean the screen. If you look thru the track you can see the bottom two bolts of the cap, it's about 5" or so in diameter. I had to take the top bolt out from under the machine with a wrench and then I could get the two from the side.
I don't know if you can remove the screen without first draining the transmission. Or for that matter even the sending unit. It is very low in the transmission.
On a different note, if your manual is like mine look in the electrical section where the gauges are. That is where mine told me to look for the senders.
JD- 450C track loader
Serial #208336T
dudedigger
Post by dudedigger » Mon Jan 16, 2012 11:59 pm
Thanks for the help it was on the filter housing under the mud. The wire was missing. Cleaned filter ,serviced trans and rewired gauge works great know thanks.
Users browsing this forum: No registered users and 244 guests
