350 track adjusters
scremineagle
350 track adjusters
Post by scremineagle » Tue Dec 20, 2011 3:41 pm
recently purchased 350 crawler tracks are fully adjusted i need to put new seals in adjusters any recomendations on if there is way to remove link when track is split new to owning crawler just replaced all rollers on one side but feel i'm gonna have track trouble with them fully extended
KenP
Post by KenP » Tue Dec 20, 2011 3:53 pm
deleted
scremineagle
Post by scremineagle » Tue Dec 20, 2011 4:10 pm
no just wondering if there is way to shorten track if so best way
jdemaris
Re: 350 track adjusters
Post by jdemaris » Tue Dec 20, 2011 5:01 pm
scremineagle wrote:recently purchased 350 crawler tracks are fully adjusted i need to put new seals in adjusters any recomendations on if there is way to remove link when track is split new to owning crawler just replaced all rollers on one side but feel i'm gonna have track trouble with them fully extended
Yes you can take a link out to get your adjusters pushed all the way back. It's going to cause you trouble later if you decide to fix the tracks with new pins and bushings. Instead of taking out a link, you might consider turning the pins and bushings if they're not worn through and broken yet.
When fixing the track adjusters, you'll find the newer style seals that the 350Cs use work much better then the ones used in older 350s. Especially in worn adjuster-cylinders. To use the new seal you have to machine out the seal groove a bit. It was standard procedure in our Deere shop.
Users browsing this forum: No registered users and 366 guests
