reverser leaking
David
reverser leaking
Post by David » Fri Mar 24, 2006 11:05 am
Lavoy, the reverser on our 1010c is leaking around the housing were it meets the back of the engine. What is the best way to stop this? does this have a gasket or seal that should be replaced?
Thanks!!
David
P.S. thanks for the discs, they work great!!
David Strickland
John Deere 1010C
Post by Lavoy » Fri Mar 24, 2006 2:36 pm
David,
If it is coming from inside the bellhousing, it could be the pump shaft seal. On some of them, there is a pressure line in there as well, it could be cracked or loose. Only way to tell is split it.
