Reverser question JD 420
mc_mike
Post by mc_mike » Mon Mar 20, 2006 11:00 am
If you remove a reverser from a transmission would the input shaft of the transmission mount up to the standard coupler on the clutch shaft from a non reverser equipped transmission? I guess what I am asking did JD use a different transmission input shaft for reverser equipped crawlers versus non-reverser equipped? I know the shaft from the clutch to the transmission is different, I am talking about the shaft in the tranny. Please let me know.
Post by Lavoy » Mon Mar 20, 2006 12:07 pm
Input shaft is the same, you will need the standard prop shaft, and the standard front bearing quill to convert to non-reverser.
lavoy
mc_mike
Post by mc_mike » Mon Mar 20, 2006 5:03 pm
Thank you for the info.
