2010 diesle head
2010 diesle head
machine shop just called my head is junk had been cracked and welded before now is leaking around the weld any ideas on where to find one? thanks Greg
Lavoy, the administrator on this board, supplies parts so he may have one or could get one.
You can sometimes find one on Ebay or Craigslist, but that is hit or miss.
There are various crawler and tractor boneyards that may have one but would require some calling around.
if all else fails, Valu-Bilt has factory rebuilt cylinder heads for a 2010 diesel but not sure if the casting number matches one for a 2010 crawler engine- supposedly the blocks are slightly different between the crawler and wheel tractors. You would have to look at the parts book to be sure.
http://www.valu-bilt.com/product_info.p ... %201193585
there was a 1010 parting out in atlanta call Kevin 770 316 7478 ......bingels on here has one i think he said he was going to sell 2010 and 1010 are the same as with wheel and crawler are both the same 2010 wheel takes a different water pump and oil pan than a crawler
