550 trans poblem
adamshuss
550 trans poblem
Post by adamshuss » Thu Nov 03, 2011 9:54 am
I am rebuilding the transmission in a straight 550. Pulled the third range and forward/reverse range clutch shafts out with ease. I can not get the first/second range shaft to come out. The book shows a coupling shaft with keepers and lockwire but the book says to just pull the clutch shaft out with the bearing and coupling still attached. Did the book miss a step or will it just pull out? Thanks
Post by digitup2 » Thu Nov 03, 2011 11:09 am
I don't think there is a lock collar on that It should just come out like the others .Digitup.
adamshuss
Post by adamshuss » Thu Nov 03, 2011 1:01 pm
I have had a slide hammer on it and it still doesn't budge.
Users browsing this forum: No registered users and 307 guests
