hyd. line
mikeintn
hyd. line
Post by mikeintn » Fri Oct 21, 2011 5:30 pm
I need the presure metal Hyd. line that runs from the hyd. pump to the tank, for a 350B dozer, setting in the seat its the line that comes out on the left side of the pump, I think its two piece, I need both, but would be interested in either one. Thanks Mike 4233239547
Michael
JWB Contracting
Replacement
Post by JWB Contracting » Mon Oct 24, 2011 10:51 am
We have replaced these with rubber hoses in the past and have not had any reliability issues. You just need to make sure that you get the correct angle of fitting on each end. The steel lines can be fairly difficult to get into place and this solves that problem. Just make sure that you route the rubber line appropriately.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
KenP
Post by KenP » Mon Oct 24, 2011 1:25 pm
deleted
mikeintn
Post by mikeintn » Mon Oct 24, 2011 7:12 pm
Thanks for the info. guys, I have thought about the hyd. hose it had one on it, I just like the ideal of the metal one, and KenP you are right it goes to the control valve, I should have said toward the tank, but anyway it is the presure line, I have had it all apart just putting it back together all painted up like yours KenP, i will put them back in the brackets to hold in place what ever I use, thats a good point, I cut me a piece hose to go around the suction where it clamps to protect it, if I dont find anything I will go with the rubber :( Mike
Michael
Users browsing this forum: No registered users and 144 guests
