jhv1050
- 40C crawler
Post
by jhv1050 » Mon Oct 10, 2011 2:27 pm
Have been working slowly on the steering clutches on my 2010 crawler. finally got the left clutcl out and apart, the clutch disc have some broken teeth on the ID. The steel plates are slightly discolored, I'm trying to determine if the steels need to be replaced. what should I look for as to the condition of the steel plates.
The brake band is junk, it was oil soaked. the old girl had about 3inches of oil in the bottom of the clutch housing. I found the bolts for the clutch housing to the trans case were loose. I thing the oil was coming around the bolts into the clutch housing from the trans.
Thanks for any input
A man can't have too many tractors!
2010 crawler/dozer
4010 diesel
1050 utility diesel
706 international
154, 184, cub lo-boy
Post
by jtrichard » Mon Oct 10, 2011 3:39 pm
are the steels flat? thats the most imporant and no rust
Post
by Tigerhaze » Mon Oct 10, 2011 9:45 pm
I think Richard stated the general consensus- flat steels can be resued if no warpage and no excessive rust or pitting- otherwise replace them.
Are you sure that the oil you are seeing didn't come from a worn seal on the final drive? Now's the time to replace while you have it out.
Post
by jtrichard » Mon Oct 10, 2011 10:38 pm
i think all of the bolt holes are blind and can not let oil in i bet its one of the two seals do you think it hyd. oil or 90 wt if your finals have 90wt.... i would replace both seals as they are most likely near 50 years old
Post
by Tigerhaze » Tue Oct 11, 2011 8:18 am
Since the bolts were loose, I would agree with Richard that it could also be the seal on the transmission side of the steering clutch housing. Like Richard said, it is probably best to change out both seals while you have apart or you may ruin another set of fiber discs and a brake band once you have it back together.
Many people also take the opportunity to replace the bearing on the final drive since it is easily accessible when off the machine.
Users browsing this forum: No registered users and 184 guests
