350c
- switchhappy
350c
i was wanting to know who much fluid am i gona need to fill the tranny and the blad resovor, and dont i need fluid in each finial clutch housing were the clutch packs are? and also what fluid goes in there ,303 in all right? and the the lower finial were the bull gear is and such takes geal oil?? thanks
350c 6 way blade, winch, log arch,,, current 3 year project of being saved and put backgether.. HELP
OIL 101
PREMIUM TRACTOR FLUID – Gives excellent results in the areas of
transmission lubrication, differential and final drive gears. Serves as a
hydraulic medium, power steering fluid, power brake and power take-off fluid
in farm tractors.
 Blended from highly refined base oils, w/superior additives.
 Approximately a 10W-20 weight with the additives
 Sometimes called ‘J20C’.
 Recommended for most newer tractors, however can be used for
older models; also safe to use - if unsure which fluid to use. Meets the
requirements of the following manufacturers’ specified products:
► IJIoIh)n Deere J20C, Quatrol, J20A (Hygrad 303)
ECONOMY TRACTOR HYDRAULIC FLUID
 TRACTOR HDYRAULIC 303 – Gives excellent results in the areas of brake
squawk, PTO clutch performance, rust protection, water sensitivity, extreme
pressure/anti-wear properties and foam suppression.
 Blended from quality virgin base oils, w/high-performance
additives.
 Approximately a 20 weight with the additives
 Sometimes called ‘303’.
 Suitable for older tractors, or where a ‘price’ fluid is desired.
 Recommended as a replacement for the following manufacturers
where a tractor hydraulic fluid is recommended:
► John Deere 303 Caterpillar
in farm tractors.
additives.
Just be sure it is a 350C crawler and not a 350 crawler with dry steering clutches- the serial number data plates on straight 350s start with "350C". I'm sure you know this but thought I would give a word of warning to others that may not
Users browsing this forum: No registered users and 355 guests
