Lavoy.....I am having a terrible time installing the final drive. (left side).Backing out the brake adjustment bolt all the way, i am finding that with the new brake band, the drum does not want to go into the new band.Any thoughts on this??
also....with the driveshaft installed in the final, how the heck is there room to fit the tranny end into the quill? I dont want to have to take off the frame rail...
this is giving me fits....
350b final drive installation
Many times the problem with the brake band is the two ends kind of straighten out instead of continuing in a circle. I often bend the ends of the band down slightly, and that usually does it.
You have to rotate the final not quite 90 degrees to get axle shaft to clear the back of the track frame.
final install
ok, will try that....thanks lavoy...
final install
lavoy, how do you mean rotate? top to bottom or front to back?
oh!! you mean on its axis.....did that, worked great.
Users browsing this forum: No registered users and 64 guests
