Measuring sprockets
18vtx00
Measuring sprockets
Post by 18vtx00 » Wed Sep 28, 2011 8:33 am
my 350B has between 2 1/4" to 2 1/2" or space at the top of the teeth. is there a spec for this? Seems too wide than the pins that are only 1.70"
DBCSteve
Post by DBCSteve » Wed Sep 28, 2011 2:59 pm
Not sure about the specs, but if the sprocket teeth are worn to a sharp point they need replacement.
JD 450C, Serial No. 316559T
Kubota L3400 top-n-tilt
Post by Tigerhaze » Wed Sep 28, 2011 4:34 pm
There are specification drawings but Deere generally doesn't release them. However it wouldn't be hard to find someone with a new sprocket since they are more common than for crawlers like my 2010.
The pockets between sprocket teeth are not supposed to be a tight fit- the indication of wear is primarily from condition of the teeth. Sharp teeth are an indication of high wear as Steve indicated.
18vtx00
Post by 18vtx00 » Wed Sep 28, 2011 6:12 pm
They are not sharp at all, they are almost flat at the tips of the teeth and about 1/4"- 3/8" wide. They were said to have been replaced w/ chains about 400hrs ago. They tried to derail on me a few times and the chains are in specs. Just thought the sprockets were not replaced and I should change them out now w/ the rollers and idler bearings that are bad.
Users browsing this forum: No registered users and 286 guests
