350B track adjusters, yes another post
Hello everyone,
I'm new to the board and look forward to being a part of it. I know there are several post on my subject and I read threw quite a few of them but didn't find what i need.
I've got a rusty track adjuster stuck good and its fully extended for some reason. It has a lot of tension on it, track is tight which will make it difficult to remove. Looking for tips on how to free it up and I'm also curious if I could just replace the rod & seals or does the yoke usually rust out too? Your help is appreciated.
P.S. This dozer will be for sale if anyone is interested. It seems to be in great shape other than the adjusters and the hour meter is showing 1070.
Thanks for your reply Lavoy. I figure they'll need to be replaced, but one is fully extended. does the yolk usually need replacing too? I've found just the piston on the internet or I've found the complete unit(aftermarket) for about $350. I guess I could cut out the tough one with a torch since it's going to get replaced.
You can also collapse the adjuster with the blade (if a dozer) or push on the fron idler with a small skid steer loader.
Lavoy sells the aftermarket hydraulic adjusters much cheaper than what you can buy on Epay, even with the shipping costs.
Users browsing this forum: No registered users and 321 guests
