obscure part number
captdill
obscure part number
Post by captdill » Tue Sep 20, 2011 4:40 pm
I am making good progress changing the left steering clutch on my JD 450 crawler. I found a bushing that needs replacing badly, but I cannot find it in the parts list. I can tell you that the shaft that fits in it is the "steering control shaft" p/n T 20728. The bushing need fits on the outboard end of the shaft. Any clues on the part number to order?
Post by jtrichard » Tue Sep 20, 2011 5:19 pm
parts book sec 5 steering clutch housing #10 part# t14368 i think is what you are looking for the part# you gave comes up for a 450B yours a B?hope this helps
captdill
Post by captdill » Tue Sep 20, 2011 6:51 pm
Thanks, but that one, the way I read the picture, fits around a vertical shaft, presumably the throwout shaft. The one I need holds the end of the horizontal steering control shaft, above the clutch. I cannot find it depicted in any drawing, but it came out with the shaft,
Post by jtrichard » Tue Sep 20, 2011 7:14 pm
the cross one are the same as vert it takes 6----- 3 each side
captdill
Post by captdill » Wed Sep 21, 2011 3:23 am
Wow, Great tip! Thanks.
Users browsing this forum: No registered users and 279 guests
