550 Trans question
550 Trans question
Have a 1977 550. 3rd forward does not pull the weight of the machine unless going downhill. After running for 30 min or so the dozer doesn' want to reverse, it will go into 1st and move but it takes a little while for it to engage. Oil is up to the proper level. Any ideas?
In nuetral at half throttle the gauge reads 60 psi. When shifted into any gear the gauge reads 80 psi. It only reads 80 psi once it is fully engaged in that gear. After running it more last evening I noticed it "slips" when put into gear but once it engages it does not slip at any throttle speed while left in that gear, so you can put it in third and it just slips but when more throttle is applied it will engage and take off, once engaged I can dethrottle to any rpm and it does not slip until it is shifted to another gear. I am planning on pulling the screen tonight.
It would be that or the oil is too light I find AW32 or THO is just too light to run in that trany but Hy Guard is the [good stuff] not a lot of difference in those oils looks wise but all the difference in the world when in there you are loosing pressure some where .What do you have in the old Deere for oil at this point ? I don't put any thing but the good stuff in the power shift units and I don't have a lot of problems with them either.Put the good stuff in and try it if you don't have any more pressure then flush it and save it for the rebuilt trany.Digitup.
I pulled the cover off the suction screen access to drain the oil and not that much came out. Are there other reservoirs that need to drain? I know there are pipe plugs on each side of the powershift housing next to the suction screen cover, If these are taken out will it drain more oil out? Which plugs need pulled?
Change oil put it at working level and make sure the screen is in a nice and clean condition If you put Hy Guard back in it will have enough additives to counter most contaminants.I don't use it any place else unless I have to but it always did a great job in the power shift transmissions .The 550B I got now has the trany filled with Hi Guard only .Even the main machines around here a 450J the 3-550Js , 650H ,750B and 850C use the good stuff in the tranys .We are more religious about that than the motor oil used even[Mostly Shell] .There is no time for down time around here so that is just what we do. .Digitup.[PS Hy Guard is made by Shell Oil but has Deere's own additives ]
put some new hy-guard in there and see what you get,I have seen off brand oils create lots of problems,including ruined transmissions.
hy-guard is expensive,but it is very stable at the pressures and temps inside clutch pack transmissions,the additives also make the friction clutches work smoothly without slipping.
good luck,hope it is not too late.
Users browsing this forum: No registered users and 539 guests
