I recently purchased a 350 that came with a 3315 winch. I was wondering if anyone new the pulling capacity of the winch and what size cable/how much the spool holds.
3315 Winch specs
Re: 3315 Winch specs
You can find specs for the winch here:aoakley321 wrote:I recently purchased a 350 that came with a 3315 winch. I was wondering if anyone new the pulling capacity of the winch and what size cable/how much the spool holds.
http://www.deere.com/en_US/cfd/forestry ... kidder.pdf
Technically that's a 3305 winch, but cable specs are the same as the 3315 and 3325 winches. I'm not sure how Line Pull translates since you have less engine, but I'm guessing the PTO may not be geared the same either.Cable Capacities*:
1/2-ln.wire rope: 185ft.
5/8-in. wire rope: 115ft.
3/4-in. wire rope: 90 ft.
*Calculated capacities-allowance must be made for loose or uneven spooling.
Line Pull (at 2,100 rpm):
Bare drum .14,500lb.
Full drum .. .. .. .. . .. .. .. .. . . . . .9,150lb.
Users browsing this forum: No registered users and 260 guests
