Flames!
63DH8
Flames!
Post by 63DH8 » Tue Aug 09, 2011 5:11 pm
I'm not too familiar with the two cylinder John Deere engines. The other night, I started my 420C to get to the master link on the track. I noticed flames coming out of the muffler's exhaust. This got me to worrying about burning the valves. Is the timing off, or could the cause be valve adjustment being off? Or is this normal?
Life is too short to drink bad coffee!
420 Crawler
Willyr
Post by Willyr » Tue Aug 09, 2011 9:17 pm
If it is a straight stack and your doing it at dusk with little light, some dull flame is normal. That being said, if you have a bright flame (did you wind it over getting too much choke?) it may be burning off some extra fuel. No, bright flames are not normal.
former owner of a 1956 420c
440 iron popper
Post by 440 iron popper » Wed Aug 10, 2011 10:48 am
It happened to me last year. After a while pushing snow, I saw quite good flames coming out the pipe! Enough to shut it down. I searched for a cause... My alternator died. The battery discharged to around 8V. So the output of the ignition coil was lower, weaker spark. I guess unburned gas from bad combustion reached the hot stack and finished to burn there. I tought I created a 5 strokes engine... I fixed the charging issue. After that, no more flames.
63DH8
Post by 63DH8 » Sat Aug 13, 2011 1:16 am
Thanks guys! I think it was because the tractor was still cold, and there was unburnt fuel in the system. You guys are great! 8)
420 Crawler
Users browsing this forum: No registered users and 75 guests
