420c right drive questions
JD Tim
Post by JD Tim » Wed Aug 03, 2011 7:49 am
Finally got the motor all rebuilt and took it out to play and noticed that the right drive doesn't seem as strong as the left one. Is there any adjustments that I could be missing in the finals(I checked the clearance between the bearing and the clutch fingers)? Or am I going to be needing some new clutches?
Post by Lavoy » Wed Aug 03, 2011 9:09 am
As long as you have freeplay in the clutches, probably no adjustment that will fix the problem.
Users browsing this forum: No registered users and 541 guests
