420C head torque specs
JD Tim
Post by JD Tim » Thu Jul 28, 2011 6:14 pm
Does anyone have the head bolt torque sequence and values? Thanks in advance.
snickers
Post by snickers » Sat Aug 13, 2011 11:55 am
Tim, number your head bolts as follows,
the bolt between the valve cover studs is # 1
then the bolt on the intake side between the cylinders toward the front #2
then on the intake side toward the rear #3 (note #2 and #3 straddle the intake port
then on the intake side at the very rear of the engine is #4
then inside the valve cover at the front is #5
the the very front next to the #1 exhaust valve is #6
the final bolt at the rear inside the valve cover is #7
the torque spec is 85 - 95 foot pounds, follow the order 1-7
(i recommend starting at a low torque like 30# and work your way up 20# or so at a time for an even torque on the gasket)
Bret
1957 420c
