350 dozer w/6 way blade (hyd. cylinder problem)
ey8675
Post by ey8675 » Mon Jul 25, 2011 11:59 am
I took left hyd arm off to put in new seal kit. Well, the cyl. has been worked on before and has a slight curve in the arm. New cyl. kit would not last w/o having a straight arm.
Where could I find a replacement (cyl. only or cyl. and casing)?
FL450B
parts
Post by FL450B » Mon Jul 25, 2011 1:43 pm
many salvage yards all over google the part it will help you find on some hyd shops may have what you need i used ed nash in nh or winggers good luck it out there
KenP
Post by KenP » Mon Jul 25, 2011 4:24 pm
deleted
ey8675
crawler cylinder problem
Post by ey8675 » Mon Jul 25, 2011 5:10 pm
Thanks Kenp for the information. I've looked on some of the sites and able to replace the spline and other parts. I don't know why I didn't think of that before I placed my 911. It's tuff when you get 70....senior brain freeze. Thanks again.
ey8675
Post by ey8675 » Mon Jul 25, 2011 8:03 pm
Well for starters, I'm near Lansing, Mi. Fifty miles from Grand Rapids, Mt. Pleasant and + 50 to Ann Arbor. I prefer good used parts and a reputable supplier. I'd be willing to drive around 100 mi. to get the right part and supplier.
Joe
gerald
Post by gerald » Tue Jul 26, 2011 10:09 pm
You will be suprise how long it will last with bent cyl, Unless it's kinked.
Cardinal
Post by Cardinal » Fri Aug 05, 2011 9:07 pm
A good hydraulic cylinder rebuild shop can straighten the rod of a cylinder assembly. Do a search on the internet for "hydraulic cylinder rebuilder" and include your town and state in the search criteria and I'll bet you will find a place that does it.
I know because I bent the lift cylinder rod on a borrowed Chevy 30 series dump truck. A new cylinder was TOO expensive. I went to Cook Brother's in Binghamton, NY. They sent the cylinder assembly to a rebuilder in Buffalo, NY (I don't have the name and address anymore). The straightend the rod, put new seals in the cylinder assembly, and it cost UNDER $200! Needless to say, I dodged an EXPENSIVE situation!
ey8675
Post by ey8675 » Mon Aug 08, 2011 11:43 am
i appreciate the input cardinal. i just got back from a camping trip and will start looking again. thanks
joe
Users browsing this forum: No registered users and 308 guests
