My 450 would not start, so I jumped the starter with a screwdriver and it turned over, but not fast enough to start the machine, I went out and bought a new solenoid and replaced it but it did not solve the problem, so I took the starter out so I can replace it, but was wondering if it is better to rebuild the one I have or buy one already rebuilt?
Starter 66 450 crawler
1966 JD 450 Crawler, 1986 Case Super E Backhoe, 2001 Kubota 7800, 1986 GMC 1 ton dump truck,1991 GMC Topkick dump truck
starter
sounds like the armature is draging on the fields if the arm is not shorted or has been so over heated that it flung the solder then you can rebuild it yourself new brushes and bushings there should be three bushings in that starter make sure you do all three i have had people tell me that the center bushing dont matter BS it has to be good or the arm drags its there for a reason i had a bad arm in my 2010 starter it was 75 for a replacment
450 Starter
Ken,
Where can I get a gear reduction starter, would Nortrax or PB&H have one in stock or is it a special order?
450 Starter
Thanks Ken,
As I can't get anything today, I may do as JT suggest and take the old one apart, if I can figure out how to rebuild it maybe I'll give it a shot, if it's over my head I'll start shopping for the gear reduction one tomorrow.
Users browsing this forum: No registered users and 248 guests
