4th gear removal
lp14255
4th gear removal
Post by lp14255 » Tue Jul 19, 2011 4:57 pm
im trying to remove 4th gear from the input shaft to replace bearings and a new cluster gear. the manual says to press off the gear, well i tried with no luck , could the woodruff key be my problem .
1969 jd350 crawler dozer
Willyr
Post by Willyr » Tue Jul 19, 2011 5:55 pm
I dont know how your gear is on. Yet on class 8 trucks (tractor trailers) a splined shaft going into a gear can get "torqued" making other wise straight splines be knocked evere so slightly out of straight. Hopefully yours is just a smooth shaft. Are you pressing this off with a hydraulic press? Have you tried to thrust the gear in other direction? As in is there a shoulder you may have been pushing the gear onto?
former owner of a 1956 420c
lp14255
Post by lp14255 » Tue Jul 19, 2011 6:48 pm
yes im using my hydraulic press . the gear is on a splined shaft with a thrust whaser then a set of gears behind it so i cannot press it in the other direction. im afraid of putting to much pressure on the shaft .
CatD8RII
Post by CatD8RII » Wed Jul 20, 2011 10:19 am
Have you removed 3rd gear yet? Its held on with a snap ring.
lp14255
Post by lp14255 » Wed Jul 20, 2011 3:21 pm
yes thrid gear is off . i know that sometimes a woodruff key can get in a bind when trying to press whatever its holding off its shaft. i took a pounch and taped down on it to release some pressure but no success.
lp14255
Post by lp14255 » Thu Jul 21, 2011 1:55 pm
well i was able to press off 4th gear on the input shaft with a little heat . i used my torch on low and only applied heat for 1to 2 minutes at tops , the gear didnt get red hot or anything like that , but can i still use this gear and not worry that it might fail later.
doc40c
4th gear
Post by doc40c » Thu Jul 21, 2011 3:25 pm
hi lp14255, as was said on other posts, 4th gear is almost never used on a crawler. i've never put mine in 4th in 20 years! so, if you were pretty easy on the heating you probably didn't change the physical properties (heat-treatment) of the gear that much. i wouldn't hesitate using it, but then again i wasn't there to witness the heating process during removal. go with what your past experiences and your gut tell you. good luck on your project! randy from michigan
lp14255
Post by lp14255 » Thu Jul 21, 2011 3:29 pm
thanks randy , it didnt take alot of heat to get it to break loose. thanks
Users browsing this forum: No registered users and 260 guests
