Need a PTO Drive Shaft for JD 350
NickC
Post by NickC » Thu Jul 14, 2011 1:32 pm
Just wondering if I can buy a PTO "powershaft" attachment for my JD 350. If anyone knows of where this assembly can be purchased either new or used, please let me know.
Thanks,
Nick C
Algonquin, IL
Willyr
Post by Willyr » Thu Jul 14, 2011 4:15 pm
Any farm tractor dealer can make you a pto drive shaft. You will need to know how much torque you require, or to tell them your application. Then with your implement attached you want to know the distance between the tractor PTO shaft and the implement shaft (you want the arms to be horizontal to the ground, the shortest distance on a tractors 3 point hitch). The inbetween shaft needs to be "sized". Too short the ends of the drive shaft will seperate, too long and you will damage the drive shaft universals.
former owner of a 1956 420c
KenP
Post by KenP » Thu Jul 14, 2011 4:45 pm
deleted
NickC
Post by NickC » Thu Jul 14, 2011 8:02 pm
Exactly. KenP. My dozer will come in real handy as a power source for a nice generator head I spotted. y machine just has the flat cover on the rear of the trans. Thanks for the suggestion.
Nick
Post by Lavoy » Thu Jul 14, 2011 9:07 pm
Keep in mind that at full throttle a 350 spins the PTO at well over 750 RPM, so make sure that anyone that hooks it up to a generator knows that first.
NickC
Post by NickC » Fri Jul 15, 2011 5:27 am
Thanks Lavoy.
From what I've learned so far, the rpm would need to be ratio'd up to 1800 for this head to output properly. No problem for the 350 with its base horsepower, torque and governing. Doesn't look like I'll be generating anything but talk unless I find a shaft.
Post by Lavoy » Fri Jul 15, 2011 8:59 am
Correct, it would be, but the input speed will be 540RPM, which is 16 or 1800 engine RPM if I remember correctly.
Power will not be an issue, just didn't want to see you blow up your fancy new generator.
Willyr
Post by Willyr » Fri Jul 15, 2011 9:54 am
Actually over turning a generator will change the cycles of the frequency. Instead of having 60 cycles per minute you may end up with something around the upper 70's? This is why some engine driven generators have a frequency indicator.
NickC
Post by NickC » Fri Jul 15, 2011 11:54 am
Just received an estimate of over $1,700 for the pto shaft assembly. Looks like I'll be generating my power a different way!
