Head gasket sealant or no sealant????
VJW
Post by VJW » Thu Jul 07, 2011 2:47 pm
Does anyone recommend using a sealant applied to a head gasket before installing it or should it be installed dry? What is the normal practice and what sealant is is used if any?
Thanks, Vic :)
Post by Tigerhaze » Thu Jul 07, 2011 3:40 pm
I can't speak to JD crawler engines, but generally for copper/metal head gaskets there is a copper gasket sealant/coating that is applied.
http://www.permatex.com/products/automo ... ealant.htm
If a composite head gasket, they are usually applied dry.
I usually use a non-hardening sealant (Permatex #2 or similar) on head bolts that penetrate water passages.
http://www.permatex.com/products/Automo ... ealant.htm
Hope this helps.
Post by Lavoy » Thu Jul 07, 2011 4:23 pm
If you are talking about a metal head gasket, ALWAYS use some sort of dressing on them. I use Copper Spray-a-Gasket or CopperKote extensively. I have also used Hylomar, but it is spendy and hard to find around here.
Post by mini kahuna » Thu Jul 07, 2011 6:25 pm
I use the copperkote as well
VJW
Post by VJW » Thu Jul 07, 2011 7:14 pm
Thanks, Actually its my Dad's 620 that blew a head gasket. I've replaced several 420/430 head gaskets and it always seems like they seep a little after a year or two of use. Usually in the winter. One fella told me to dip them in oil before I applied them and I have heard of many guys using a variety of different products. I will try and get some copperkote tomorrow. Good info! :D
Post by Lavoy » Thu Jul 07, 2011 7:58 pm
Oil is the prescribed installation method according to Deere, the copper sprays are a lot less messy I think and stick around longer term. I would use the copper sprays on the 620 as well.
I have heard of people using aluminum spray paint, but the cost is no different than the products designed for gaskets applications, so have never tried it.
