350c steering valve adjustment
- dozingdozer
- 420 crawler
folks, I have just rebuilt my steering valves on a 350C with new seals, O rings and springs. They are adjusted and it works OK but i am wondering if anyone has adjusted the travel on the vlaves by just measuring the travel distance of the valves from the housing? It seems this would be easier than what the manual says and realize there will be various play and wear on the linkage. thanks , dd
76 JD 350 CE dozer-85 Vermeer 434 trencher w/bhoe
- dozingdozer
- 420 crawler
have you ever measured the ditance to ball park adjustments
Cat, have you ever measured the distance to ball park adjustments from the housing or other refernce point?dd
