track adjuster guide bracket
truck209
Post by truck209 » Fri Jun 17, 2011 2:40 am
Track adjuster guide bracket on 350 c dozer 1975 seems to pull up above bolts on when dozing. how would I fix this. Had too replace old adjuster it cracked on main body.
KenP
Post by KenP » Fri Jun 17, 2011 4:50 am
deleted
Willyr
Post by Willyr » Fri Jun 17, 2011 6:03 am
I wonder if his shims are missing that holds the idler to the carriage?
former owner of a 1956 420c
Post by Lavoy » Fri Jun 17, 2011 7:47 am
You will most likely need to remove the front idler and replace the wear plates on the idler brackets and track frames. They are current from Deere, or I can get them as well.
Users browsing this forum: No registered users and 243 guests
