JD350 Loader Control Valve Spools
deleted
Ken
I cant say for sure if it can be done in the machine. I took mine out to work on it. Arent the o-rings you need to access fairly close to the end of the valve body? Provided you can remove the end caps and centering springs in the machine, you should only need to push the valve part way in the bore to get to the o-rings.
kemp. I had to remove the valve body an split evey section there are 6 0rings between evey section the 0 rings are thin true value had them. My out rigger where sticking after the re build . Take the pin off the controal lever , remove the bottom cap an push the spool from the top that is it, The out riggers have a nut an spring but come out the same way.Im thinking now I had to remove the bolts to lower the contoral valve with a good rope an comalong secured to the boom. Loder control I got it wrong just discribed hoe controal valve
Users browsing this forum: No registered users and 264 guests
