backhoe attachment for a 1964 2010 cralwler
JAMESBARTH
Does any one know what backhoe fits on my 2010 and were can I find one. old or new,It looks to have a attachment and hydraulics all ready fo it.
- Little John
- 430 crawler
Backhoe
James, I don't know where you are located but I have a Model 51 Hoe Attachment that is missing one cylinder (robbed for a log splitter) and a couple of blownout valves, otherwise complete. I bought it used, from a fellow that had it on his 2010. I used it on my 440 back in '75. Been sittin' here since. Located in N. Central Md. if you can come this far and use it e-mail me Thanks, Mora
- Little John
- 430 crawler
Backhoe attachment
Model #51 Hoe Attachment sold
tonyrb
Backhoe Attachment for JD 2010 Crawler
Hi, I have two JD 2010 Crawlers one has 4n1 Bucket along with backhoe and a Dozer with a 6n1 blade. Where do i look to find out which backhoe attachment it is. I will go and take a look today 5/29/06.
Also I am looking for a additional engine or just the block for a 2010 JD Crawler Dozer i think it is a 1962 Jd 2010 crawler dozer.
Thanks,
Tony
Thanks,
Tony
Anthony R. Blanchette
- lastchancegarage
2010 serial numbers
Tony,
Welcome aboard. This chart came off a different area of this site. This will help you determine the year of your machine.
2010 Serial Numbers
All 2010s used the same serial number range
Year Beginning S/N
1960 10001
1961 10991
1962 21087
1963 31250
1964 44036
1965 58186
Hope this helps.
2010 Serial Numbers
Year Beginning S/N
1960 10001
1961 10991
1962 21087
1963 31250
1964 44036
1965 58186
Hope this helps.
1959 JD 440 ICD dozer
195? ATC GT-25 dozer
- Little John
- 430 crawler
50/51 backhoe attachment
Tony, The 50 model is an non-movable 'center of tractor model', the 51 is a 'movable' i.e. Slide backhoe, that allows you to move it left and right of centerline of the tractor. The s/n on the 51 is high on the front of the out rigger mounting frame closest to the tractor. (Left or right side, can't remember which). It is visible from a rear facing (BH)operators seat.
