trany rebuild
lp14255
trany rebuild
Post by lp14255 » Wed May 11, 2011 7:47 pm
im having to replace my second gear and will have to tear down everything to pull the output shaft and ring gear , will it be ok to just put it all back together and not check for shimm tolerences or take the time and check them all.
1969 jd350 crawler dozer
KenP
Post by KenP » Thu May 12, 2011 3:04 am
deleted
Post by Lavoy » Thu May 12, 2011 8:51 am
If you are that far in, I would recommend replacing the bearings while you are in there. What if one of them was about ready to have a bad roller or something? A new set of bearings is real cheap insurance compared to broken pieces later due to a bad bearing.
lp14255
Post by lp14255 » Thu May 12, 2011 3:01 pm
are talking about the ring bearings or all of them .
Post by Lavoy » Thu May 12, 2011 3:31 pm
Every single bearing in the transmission.
lp14255
Post by lp14255 » Thu May 12, 2011 4:56 pm
thats the plan
Post by Lavoy » Thu May 12, 2011 8:08 pm
Check shafts for grooving where the seals run too, not always a big deal, but sometimes they get grooved or corroded. Wash the case out really well so no shavings, filings and such remain.
lp14255
Post by lp14255 » Sat May 14, 2011 12:44 pm
It's kind of like a trany build on my truck , make sure everything is clean and replace everything. It's safe insurance.
Users browsing this forum: No registered users and 259 guests
