6 way blade controls
I have a 350C when I turn the blade left or right and try to raise at the same time the blade falls. Is this normal behavior for the controls?
- Willyr
nope.
The valve port should hold a cylinder no matter where you put it. I am not familiar with your tractor. Yet it sounds as if you have a blown o-ring in the valve body. There maybe a kit for repairing it from Deere.
former owner of a 1956 420c
- Willyr
V-type seals are o-rings. They are a better type seal. Basically when pressure hits them they expand making the best seal.
John Deere should have them.
I think in many applications the hard V-type and soft O-type are interchangeable. On my JD 2950 tractor almost every O-ring on the machine was originally a plastic V-shaped ring. Well, long story short, unlike rubber o-rings, when they get old they get brittle and crack. That's why this series of tractors are widely known as rolling hydraulic leaks. Whenever I get a replacement from JD, they always give me round rubber ones to replace the original plastic V shaped ones.
- Willyr
v-rings otherwise known as wiper rings.
Users browsing this forum: No registered users and 376 guests
