JD430C
Post
by JD430C » Sat May 07, 2011 6:54 pm
Well back in the fall I traded my 430c for a 550 with a tranny problem. The tranny lines were vibrating and making lots of noise. Also the crawler would work for a little while and then stop. Book made it sound like the tranny pump was the problem so today I started prepping it to remove the pump. I found the problem when I pulled the suction screen out.
I dont think the screen had ever been cleaned. Took quite awhile to get it cleaned.
Worked the crawler for about 45min tonight and everything seems to be ok.
Andrew
Post
by digitup2 » Sat May 07, 2011 7:59 pm
Ya that would do it !Digitup.
JD430C
Post
by JD430C » Sat May 07, 2011 8:09 pm
I am hoping nothing was damaged as a result. The previous owner installed a new tranny pump just before I bought it hoping that would fix it. Time will tell.
Andrew
JD430C
Post
by JD430C » Sat May 07, 2011 9:26 pm
Digitup, is there a way to adjust the rate of shift? Its really snappy going from forward to reverse. I scanned the tech manual tonight, but I couldnt find anything on adjusting it.
Andrew
gerald
Post
by gerald » Tue May 10, 2011 6:03 am
I know the feeling of lucky, that looked like my Hyd screen befor I cleaned it . that is one reason my 350 was sold so cheep the hyd shuddered because of a cloug filter screen. The machine is parked thinking its broken.
Post
by digitup2 » Tue May 10, 2011 2:28 pm
yes but that was something I never touched.I know there was adjustment there for shift rate though.Digitup.
JD430C
Post
by JD430C » Tue May 10, 2011 3:27 pm
I found it today in the tech manual, adjusting it right now. The PO monkeyed with that too
Will give an update and pics tonight.
Andrew
sdluceywv
Post
by sdluceywv » Sat May 14, 2011 1:03 am
Hello, new to the board and thought I should throw in my 2 cents, since I am gonna be doing some brake work in the near future and will be asking a lot of info from you all!
Having the same problems as you, we had to cut the outer cover off the strainer to get ours completely clean, then re-weld it. I would recommend checking this screen as often as you can stand, as it seems to fill back up quickly when its clogged to this degree. We have done so over the last six months of intermittent farm use, and finally it remains clean.
Willyr
Post
by Willyr » Sat May 14, 2011 5:15 am
If your screan is dirty seems to me it should be possible using a parts washer to backflow the screen thus removing the particulate?
sdluceywv
Post
by sdluceywv » Fri May 20, 2011 9:25 pm
Our screen was not able to be cleaned that way, but I do think there was an incorrect/incompatible additive or a stop-leak or seal conditioner present. The screen was clogged with the usual dirt and metal, but also with a teflon-like substance that was impossible to remove through the intake opening. If the screen is clogged with the usual dirt and metal, I would say you are correct.
JD 550
Users browsing this forum: No registered users and 249 guests
