chumbrothers..1978 JD 350B loader
carolina crawler
Post by carolina crawler » Thu May 05, 2011 7:38 am
1978 350b loader w/winch
CatD8RII
Post by CatD8RII » Thu May 05, 2011 5:45 pm
Nice log arch and factory ROPS. Is the new pad sitting on the track to compare?
carolina crawler
Post by carolina crawler » Thu May 05, 2011 6:29 pm
yea, pads and chains, worn out down to the bolts....lol its a great little crawler, the previous owner just had a new crank and pistons, etc installed in 06, just hear something in the center of the crawler, not sure if its normal or not, and I got another bucket for it, as that one is ripped, going to re-weld it and put new teeth on and use it to move rocks..Thanks for the comments.......
carolina crawler
Post by carolina crawler » Thu May 05, 2011 6:33 pm
log arch? that the same as a winch?
Post by Lavoy » Thu May 05, 2011 7:54 pm
Noise in the middle could be isolator problem.
CatD8RII
Post by CatD8RII » Fri May 06, 2011 7:11 am
The log arch is an attachment for the winch, its the tall mast with the rollers. Some machines have just the winch. The idea ,when skidding logs, is to pick up the front of a log(s) to keep it from digging into the ground, and to transfer some weight onto the crawler for extra traction. And yes the noise in the middle could be the isolator. Even when they're brand new they're noisy as heck. I wonder if the previous owner had that redone when he did the crank?
carolina crawler
Post by carolina crawler » Sat May 07, 2011 5:32 pm
reading thru previous post, I see were this isolator is quite popular, I would hope that the shop that did the engine, did install a new isolator, as they were a Deere crazy shop, they love them deeres in North ga< I have reciepts, I need to look thru them ,just got back from SC, cutting some trees, and doing some grass trimming, cant wait to get that little crawler in the Sc mountains.........Dirt its gona move...giggity...I do need to locate a cable for this winch though and repair the handle, it broke..thanks again for all the comments, God Bless America and The JDC website.............. :D
Last edited by carolina crawler on Sun May 15, 2011 6:37 am, edited 1 time in total.
carolina crawler
Post by carolina crawler » Sat May 14, 2011 6:01 am
Image[/img]
new adjusters and spring covers
carolina crawler
Post by carolina crawler » Sat May 14, 2011 6:02 am
Image[/img]
