oil dipstick tube
RMAC
oil dipstick tube
Post by RMAC » Sat Apr 23, 2011 10:20 am
I'm looking for the tube that screws into the engine block, on my 66 450, the original broke off, I was able to ez out the broken portion, but I'm missing approx. 1/2". so I probably won't get an accurate read on the oil level, the original is about 4.5" long. Also I have some minor oil leakage coming fro the flywheel on the front of the engine, does anyone know if that has a gasket that can be replaced or is that more indicative of a bigger problem?
1966 JD 450 Crawler, 1986 Case Super E Backhoe, 2001 Kubota 7800, 1986 GMC 1 ton dump truck,1991 GMC Topkick dump truck
Post by digitup2 » Sat Apr 23, 2011 5:41 pm
You can order the dipstick tube right from Deere and the dipstick you have should work if the tube is properly installed dose it go in the block or the pan most go in the block.The leak at the crank end can be fixed with a gasket set but be prepared to pull the pan .Digitup .
RMAC
Post by RMAC » Sun May 01, 2011 5:51 pm
I had to buy a new dipstick, along with tube, as the new tube won't accept the old dipstick, it seems as if the original one is no longer available. I bought a used tube from PB&H in Antrim NH (They're a great place for older deere parts) and a new dipstick at Nortrax. Know all I have to do is fix the leak in the crank.
Users browsing this forum: No registered users and 272 guests
