Rear sprocket hitting lower roller
The rear sprocket on my 350 is hitting the lower roller causing the track to lock up. I checked the bearings in the final drive and they appear to be good. Has anyone ever experienced this or know what the problem might be?
You lift/jack that trackframe off the ground, release tension on the track, and check the roller for worn or stuck bearings.lawsonj5 wrote: Also, how to you check for a bad roller?
Ok, I pulled the track and skid off tonight. Found out there is lots of slop in the final drive and one bad roller. I'm assuming the bearings are shot in both. Guess I'm going to have to pull the final drive and see what everything looks like inside and see if its rebuild able. Anything I should look out for?
Users browsing this forum: No registered users and 256 guests
