1010 crawler track
1010 crawler track
I have a 1010 crawler with a rock track, and would like to find a track suited for dirt.
Okay, now I get it.
The flat pads are called street pads, and are for working on hard ground and cement. On a 1010 they would be called 3 bar semi-grousers. They are seen most commonly on loader crawlers.
The other pads are called grouser pads.
If you have a loader crawler, grouser pads will increase wear and tear on undercarraige and steering clutches significantly plus require a great deal more power to turn. If you are always on soft ground or in mud, then not nearly as bad as if you are in dry ground.
