Lavoy was correct in diagnosis...350c reverser
Cuzz
Post by Cuzz » Thu Apr 07, 2011 3:28 pm
Lavoy, you were right about the bearings in the reverser. They were trashed to the point where it messed up a few clutch plates. The splines on the reverse end of the reverser shaft are almost sharp enough to cut you and the shaft tappers down a lot. I found evidence of a previous catastroffic failure where the bell housing had a 1"x4" hole in it and a crack that had been welded almost 50% around the bell housing.
Now here is my question:
I have found a local salvage yard that has a complete reverser from a 350. He wants $1700 for it and it is setting on a shelf. They have opened it up, inspected it, and buttoned it back up after resealing everthing. 15 day warranty. Will this 350 reverser work on a 350c? Is the price reasonable?
Thanks for everyones help and input.
Thanks,
Cuzz...
My wife says I never listen to her.... or something.
Post by Lavoy » Thu Apr 07, 2011 7:30 pm
Someone else will have to answer if it will fit or not, I am not sure.
As to price, if your case is good, and for not much over the $1700 I could rebuild my own reverser and know what I have, I would go that way.
Post by mini kahuna » Fri Apr 08, 2011 3:56 pm
if you are not pressed for time I would tear down the one you have and see what's going on in there.
you can carefully rebuilt it with care and it will last for many years.....buying a used one and putting it in is a gamble at best.
Users browsing this forum: No registered users and 304 guests
