1970 350 pump .
1970 350 pump .
Help with pump. The machine starts an idles fine other then the pump leaks diesal from the slow an fast idle control cap.The pump is CBC311 Roosa 2500 rpm. I did a search it's still rebuilt or a easy fix from me, that would be different easy button , this number didn't come up 1348332 .The price of diesal I think its worth fixing. Thank you gerald.
KenP wrote:Gerald, I don't understand your post other than your C series injector pump is leaking.
Look at this thread. Same pump, same leak. Kemp I got the name of the parts stright from the manual and that is where the diesal is leaking. Thank you for the search.
http://www.jdcrawlers.com/messageboard/ ... php?t=5842
Users browsing this forum: No registered users and 266 guests
