350B Engine Removal
DavTom
350B Engine Removal
Post by DavTom » Wed Mar 30, 2011 9:08 am
Can the engine, radiator, and pump be pulled as a unit?
Also, are there any hidden bolts that will require dropping the belly pan?
Just got the final drives back on and test ran it when all heck broke loose in the flywheel area... Now pulling engine to find what happened... Hoping it's just a clutch...
Post by Lavoy » Wed Mar 30, 2011 9:30 am
No, pretty sure you will have to take them off first, but could be wrong.
Shouldn't be a clutch on a B model, most like it is an isolator problem.
Post by Tigerhaze » Wed Mar 30, 2011 9:50 am
DavTom-
Here are some threads on the torsional isolator in case you are not familiar with the issue:
http://www.jdcrawlers.com/messageboard/ ... c+isolator
http://www.jdcrawlers.com/messageboard/ ... t=isolator
DavTom
Post by DavTom » Wed Mar 30, 2011 9:51 am
Thanks Lavoy...
The tech manual isn't very thorough on the engine removal procedure, only dedicated a couple paragraphs to it... But I did find a note that says Alternate method would be to remove the engine, radiator, and pump with support as a unit... So I guess I answered my own question...
Found the flywheel area in it now, with reverser it has an isolator, without reverser it has a clutch... Mine has a reverser so I guess (hope) it's a busted isolater...
The clutch adjustment gauge I purchased from you worked great on the steering clutches...
DavTom
Post by DavTom » Wed Mar 30, 2011 10:05 am
Thanks for those threads Tigerhaze...
KenP
Post by KenP » Wed Mar 30, 2011 11:57 am
deleted
JWB Contracting
350B Engine Removal
Post by JWB Contracting » Wed Mar 30, 2011 5:14 pm
Yes, you can pull the radiator, hydraulic pump and engine as a unit.
You need to remove the hard nose and stump pan. You will need to drain your hydraulic fluid.
I believe there are 6 bolts which hold the engine in, 2 on each side of the engine when looking from the front and 2 from the top of the bell housing side.
Watch out for the reverser cooler lines and power assist on your steering, water temp, oil pressure, tach etc.
Our 350C's have been rewired and we don't reinstall any guards, and leave the front floor boards out. With two men, we have pulled an engine in 37 minutes.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
DavTom
Post by DavTom » Thu Mar 31, 2011 2:22 pm
Engine is out...
There's something missing here...
Here are some of the missing pieces...
Pulled the front section of the pan but found out I didn't have to after all...
It's not easy to get a 6'2" 275 pound man under this thing...
There are only 4 bolts holding the engine to the rest of the driveline...
KenP
Post by KenP » Thu Mar 31, 2011 5:39 pm
deleted
DavTom
Post by DavTom » Thu Mar 31, 2011 6:03 pm
Is there anywhere other than a JD dealer to get these parts??? $$$$$$$$$
KenP
Post by KenP » Fri Apr 01, 2011 7:44 am
deleted
Post by Lavoy » Fri Apr 01, 2011 7:56 am
Nope, they are all Deere parts only.
The late style torsonial isolator is obsolete, as is the flywheel you need to do the conversion. Last three isolators I bought from Deere the week they went obsolte were $1500/each.
I have all of the research done and a manufacturer to make the isolators for me, just had not done it due to lack of demand. I know where there are a few flywheels left, so that is not a big deal. If enough people are looking for the late style isolator, I will dig my notes back out and look again at having them made.
DavTom
Post by DavTom » Fri Apr 01, 2011 8:05 am
KenP wrote:Your cost is going to depend on how you want to fix it.
The spring isolator system is no longer used and there is a replacement system to use in its place.
Try this thread. It contains what you need to know to make a decision:
http://www.jdcrawlers.com/messageboard/ ... php?t=2823
The new style listed in that thread is no longer available from JD so looks like I'll be rebuilding this one...
Looks like around $1700 for everything to patch it back up...
Post by Lavoy » Fri Apr 01, 2011 10:12 am
That seems a little high. If you want to e-mail me that part numbers, I can see if I can save you any money.
DavTom
Post by DavTom » Fri Apr 01, 2011 11:15 am
A couple of the parts I looked at came with one of the other items so I didn't need them, brought the total down to just under $1500...
1 - AT315819 - ISOLATOR,FLYWHEEL 971.80
1 - JD9449 - BEARING, BALL 8.65
5 - T55320 - RETAINER,SPRING 32.45 each = 162.25
5 - T29675 - SPRING ,ISOLATOR 51.04 each = 255.20
5 - T29706 - ANCHOR ,FLYWHEEL SPRING 11.64 each = 58.20
5 - 25H1052 - PIN, TAPERED AND GROOVED 1.37 each = 6.85
5 - 19H3032 - SCREW, HEX SOCKET HEAD 3.29 each = 16.45
Users browsing this forum: No registered users and 186 guests
