John Deere 420 Crawler Parts
dr.fireman10
Post by dr.fireman10 » Tue Mar 22, 2011 4:27 pm
Have some extra crawler parts:
Two Front Idlers $100 each
L and R Steering Clutch Housings $100 each
Direction Reverser (Gear Type) $300
Ring and Pinion (some pitted teeth but solid) $100
Drawbar $100
Good Transmission Case M4002T $100
Few other misc pieces, these are from a 1957 420 Crawler.
Call (330)416-4613 or e-mail a message, Im in North - Central Ohio.
JD 430C 40V 420S 430S 430W 430T 435 630S
gus
Post by gus » Tue Mar 22, 2011 7:02 pm
PM sent on the reverser
Swawpy
Post by Swawpy » Tue Mar 22, 2011 10:15 pm
I'll call 2nd dibs on the reverser if it does not work out with Gus!
dr.fireman10
Reverser
Post by dr.fireman10 » Wed Mar 23, 2011 7:26 am
Trying to attach a picture of the reverser pieces.
Everything is solid, there was some rust that I cleaned up and all the bearings will need to be replaced.
A fella had sent me a message about the unit last night right after I had posted the parts, Ill try to get in touch with him first to see if he is interested. If not Ill jump to the next in line.
Thanks, Dave
