350 dozer reverser leak
ssdgarrett
Post by ssdgarrett » Sun Mar 13, 2011 9:49 pm
I am hoping that someone with some experiecnce with 350 dozers can shine a light on a question that I have. I just purchaced a 1969-70 model 350 dozer from a neighbor that had her husband pass away. It had a problem that developed when he was out piling brush with the dozer. It developed a severe leak on the left side front corner of the belly pan area. It looks like it may be coming from the reverser area. I understand that the reverser has a couple of hoses and I am suspecting that one of those hoses had a stick run through it. How hard are the hoses to change and does anyone have any tips on how to make the job easier? I am assuming that once I get the belly pan off and get under the dozer it will be apparant where the leak is coming from. Does this sound logical or am I all wet on this problem?
gerald
Post by gerald » Sun Mar 13, 2011 11:03 pm
I can't remember any hoses under my 1970 350 crawer. Drop the pan an look on the right side in the middle there is a plate on the side with 3 7 1/6 bolts that would be the reverser reservoir an filter. With luck it may be something easy.
Post by Lavoy » Mon Mar 14, 2011 10:01 am
Could be reverser cooler hoses are leaking. Get all of the mud and crud cleaned out that you can after you remove the pan.
vestor_guy
Post by vestor_guy » Mon Mar 14, 2011 5:47 pm
I completely rebuilt an early 350 once and I remember that the oil cooler lines were in two sections with a hose and clamps between the two lines. The newer models eliminated the hoses and use metal to metal connectors and a longer front line.
That is indeed the most likely source of a leak and just replace it with some good hydraulic hose.
To get the pan off, I just used a block of wook and a floor jack. I think the hoses go down the left side in the area of the side frame.
vestor_guy
Post by vestor_guy » Mon Mar 14, 2011 6:02 pm
I just read your post again and the leak in the fwd left corner. There are also hoses on each line there. You may not need to drop the belly pan. I don't remember exactly but you may be able to enter by removing the grille. Worse case, you pull the front shroud.
ssdgarrett
Post by ssdgarrett » Tue Mar 15, 2011 6:28 pm
Thanks for your help
Users browsing this forum: No registered users and 299 guests
