Ripper/3 pt for my 350
Rick Kr
Post by Rick Kr » Thu Mar 10, 2011 10:01 pm
Its getting warm and starting to think through my summer dozer projects.
I am planning on expanding my pond this year. I want to scrape the top soil off and save for later. Then excavate out the the clay.
I have cut sod before with my 350, but I think doing a 150' x 150' area might be a little too hard on the dozer without breaking it up first.
I was thinking of a couple of options for tearing up the top soil.
1. 16 inch rippers (sub-soiler)
2. plow
or find a ripper/3 pt set up for the dozer.
My gut feel says plow or sub-soil with the tractor since I already own the equip, and not spend time/money on a ripper for the dozer.
Plus I can cover the ground a lot faster on the tractor. Then pile the top soil with the dozer.
Am I thinking right here?
Rick
JD 350B, 6 way blade
NH3930 4x4 w/loader & tree spade. AC WC.
Post by digitup2 » Thu Mar 10, 2011 10:43 pm
I have done it before on heavy well established sod works great I have an old 8 furrow disk plow that is large and heavy.Roll it over once and it breaks up real nice with the blade . Saves time and fuel and you need time on your side with a little 350 dozer .Digitup.
vestor_guy
Ripper
Post by vestor_guy » Mon Mar 14, 2011 8:41 am
A ripper on a 350 is not a very efficient method of loosening the soil. It will help if the soil is VERY hard where other methods wont work.
I use an ag tractor and disc to loosen. A 350 will not do much digging and pushing at the same time. You can disk 4 to 5 inches and the 350 will push loose dirt quite well. Just remember to steer with the blade tilt and not with the clutches to be most efficient.
Users browsing this forum: No registered users and 258 guests
