440 gaser oilpump install
rebuildin motor and manual says i need tool to properly install oil pump? or should i say time it.
1960 440ic,831 loader,51 mc
I think you can allign the slot and narrow side to the outside by a little trail and error engaging the spiral cut gears. I believe you can see down the distributor shaft to see if the drive meshed correctly (slit parrallel to block with the slot offset to the outside of the engine). This allows the distributor to be installed and timed correctly.
Chuck
Chuck
Users browsing this forum: Google [Bot] and 349 guests
