1970 350 clutches an final
It's going very good and easy. I used the motor cycle jack striped the final down pulled stright out about 4 inches. Bearing was in backwards on final wrong bearing it was not even close to the race , the quil pinion bearing is right. Lots of oil an dirt . I have evey thing on order. I'll work on some pics. Amazing what happens to these old crawers.
Im wrong about the final shaft bearing the number is good but was never seated in enough. It looks like a job getting it in the final houseing ,may be put the final shaft in the refrigerator . It took out the pinion gear and I have one on its way along with bearings an seals. still have one more side to get should be easier because its not full of oil could be rusted up.
Users browsing this forum: No registered users and 256 guests
