Installed both final drives and adjusting the throwout bearing and new brake bands. During this I noticed that on one drive, the brake band appears to not be on the drum parallel to the brake drum. I believe the brake band may be hung up a little either on the drum or more likely, pushed in a little on the bottom where the final drive pin goes through the loop in the band. I tried loosening the band and readjusting it but it seems to not want to move and align.
Will this align on it's own or do I need to partially pull the final and try to get this aligned? Looks to be out of parallel by about 1/4". I am judging alignment by looking from the top cover opening and seeing on one side of the drum a space of about 1/4" between the edge of the band and the edge of the drum and by the time the band loops around the drum, it is even with the edge of the drum. Band is not overhanging the drum, just not sitting on the drum straight.
Suggestions?
440 Brake Band Installation
