420 Front idler spacer
snickers
Post by snickers » Thu Feb 10, 2011 9:07 pm
Has anybody built or have the specs on the front idler spacer? Part # M2814T
wanted to know if its hardened? and Dimentions
1957 420c
Post by Lavoy » Fri Feb 11, 2011 8:47 am
I am working on new ones, got the die made, just don't have enough push.
snickers
Post by snickers » Fri Feb 11, 2011 10:44 am
how big is your press?
i was going to build a die set for them but really need to know what the dimensions and type of steel they were built from? the ones that were on my machine are so bad that i cant even measure the diameter of the bolt.
any ideas?
1957 420c
Post by Lavoy » Fri Feb 11, 2011 3:21 pm
The rod is an odd size, not commonly available, the guy that is making the blanks for me located it.
I have a 20 ton press, not even in the ballpark as far as what is needed. Going to remake the die and put it in a 200 ton brake and see what that does.
foxd
Post by foxd » Wed Apr 03, 2013 7:40 am
Did you ever have any luck making some of these spacers? I am in need of a pair.
Thanks Dave
'39 B, '48 B, '49 A, '50 B, '54 40U, '55 40U, '59 430U, '60 430C
Post by Lavoy » Wed Apr 03, 2013 7:51 am
I don't have enough press to do it, so nothing yet.
Users browsing this forum: No registered users and 479 guests
