Little wood cutting
Lavoy, a question for you. The snow pads have a hole in them for the snow to push out of you would adjust the tracks to normal spec's. Correct?
Digger, nice looking crawler. The trailer looks a little under built to be behind it.
Dan,
Dan,
1956 420C with GSC blade
- JD440ICD2006
Those two cyclinder engines are amazing. I realize that the trailer is not much of a load for it, but they will still surprise folks with what they will do.
You have the perfect deep snow firewood rig!
Temps here have been in the Teens ..single digits. It sets for about a week. No block heater or hose heater of any kind, and she pops off even with no choke about one turn of the starter.
Just have really impressed so far. Can't wait till this summer and see what it can do with the dirt and rock.
Although.... with the frozen ground up here, damn near throws you out of the seat pulling it out of the shead and on plowed spaces.
Thanks for all your comments
440 IC #448161 W/Henry loader, 3020 D, #8 mower
- mapaduke@yahoo.com
Re: Little wood cutting
I was going to make a comment about how much the background of that photo looks like where I live, but then I realized that IS where I live. I drive past your house every dayDigger SR wrote:
Guy got stuck out on the farm... Tried to drive out back to do some shooting when there was deep snow on the roads. Luckily for him I was messing around in my shed. Since it was so cold I told him I'd pull him out with the 420 since none of the diesel tractors were going to get started for a while. He looked at it like you'd look at a pedal tractor but he was up for anything. It fired up on the first revolution and we headed out with a chain, hooked up, and I told him to just put it in neutral and let the little crawler do everything.JD440ICD2006 wrote:Those two cyclinder engines are amazing. I realize that the trailer is not much of a load for it, but they will still surprise folks with what they will do.
It was a fullsize pickup that he bogged going downhill, with a head start, in 4 wheel drive, in 2 feet of snow. That is how stuck it was. Hauled him right out of the mess without slipping once.
